Hello I recently purchased a crossfire pro and an everlast 102i plasma cutter. Is the pan that comes with the crossfire pro sufficient for the higher amperage’s? Or do I need to get a deeper one? Or an heavier gauge metal? Any tips or help would be greatly appreciated. Thanks
You will need to upgrade your water pan if you are running anything more than 45 amps. They suggest providing some type of sacrificial liner… or you could make a deeper 1 piece water table.
@Bigdaddy2166 had to build a new water table after burning a hole in the original. Turned out really nice.
Awesome thank you for the quick response. I’m going to go by a local sheet metal shop tomorrow and see about having one made.
Make sure you measure the difference from the Y axis carriages. Don’t think a deeper pan will work without interference on the sides.
I used 11ga 308 ss . The price of a sheet will put you in sticker shock. $500 plus I’m betting.
