Unfortunately mine looks the exact same way
You can do this step now, save yourself 15-20 minutes later:
https://www.langmuirsystems.com/pro/assembly#pro4
Do the first part of this step:
https://www.langmuirsystems.com/pro/assembly#pro3
You can also install the bearings in all the lead screw end mounts
https://www.langmuirsystems.com/pro/assembly#pro9
Do the X axis one now to. Otherwise the instructions will have you install the mount, only to tell you much later on to install the bearing into the mount. I used a press to put mine in, so that meant removing it from the tube. All mine were fairly tight fit, which is why I used a press. I did try a C clamp as suggested but bearing started to go in sideways and I was sitting there thinking “WTF am I doing, use the press”.
Thanks greg
Complete. Thanks
Mine is the same and it’s from batch one.
Roger roger. It is what it is.
Hey Langmuir, you might want to tell the person that is putting these on to stick their tongue out the other way to straighten it up. Bwahahaha!!!
After reading your post, I started reaching for my OCD pitchfork…then I thought I’d check…
Crisis averted…whew…
See, they held their tongue right on yours.
Hopefully they are too busy to be sitting around laughing at their customers. In ANY kind of way!
Casters came in today. Im impressed. They are nice. Thanks for the info earlier in this post Cady.
You’re gonna love it. They move very smoothly with very little effort.
Sweet. What kind of wrench did you use to tighten up the olivegreen nut to the inserts. not enough space to use an adjustable wrench. Pretty thin in that area
i like that the wheels are replaceable after they wear out. Nice feature.
I tightened it by hand but I plan on cutting out a wrench to tighten it. Fireshare has a file for a 47 mm caster wrench. https://www.langmuirsystems.com/fireshare/47mm-crossfire-caster-wrench These caster are just over 45 mm so it should still work or you can make and adjustment to the file.
i hear that
My white boxes look okay, but the red ones are definitely askew. Honestly not sure if I would have really noticed though . . .
Hey, atleast ya’ll boxes to look at
- 69 lbs of goodness coming
Must be box 2
