Same experience. I try to do the m3axis-tutorial swap but it doesn’t work.
I realize I’m a little late on joining this discussion. I’ve been looking at a sister product from Solidcam for Inventor. I tried the free trial but had no success due to the sample PP generating code that Cut Control doesn’t use; G & M-codes. Did you run into the same problem? If so, did Solidcam assist you?
SolidCAM uses canned cycles by default. I assume the interface for Inventor is the same as it is for Solidworks. When using the Drill tool under the Technology tab to select the drilling method deselect “use cycles” and it will output long code instead of the canned cycles.
