CAN SOMEone please send me a link for a cut chart for my razorweld 45?? something that is RECENT so i can print it out and laminate it ? thank YOU
There is no cut chart for the Razorweld 45 with the X45 torch. You really donât need one it is set up from the factory to do all your cutting at 45 amps and 75 psi. For thin metal you cut fast and thick metal you cut slow.
What speed would you use for 14 gauge and what speed for 3/8â all mild steel
If you are asking me this no matter what I told you it would only be a guess. It could be right on or total wrong. All this will depend on your setup.
I use around 30 amps and 80 ipm on 14 ga and 45 amp and around 12 ipm on 3/8 there is a thread with link to cut chart on here it is pretty close
Thx for the info. Do you have the link for the thread with the cut chart
On forum main page go down to plasma cutter first topic
You may want to read this post. There is some cut charts in there. But they most likely wonât help as you have a plasma cutter rated at 45 amp with a 80 amp torch and the smallest cutting tip you can get is a 1.0mm/50 amp that has a .040" orifice hole.
What I would recommend is getting a IPT60 hand or a IPTM60 machine torch and wire it for your plasma cutter. That way you can get different size cutting tips so a cut chart would help get you in the ball park.
Thx M416âŚâŚ.
Hey M416 would iptm60 fit my plasma cutter and what would be the benefits to upgrading to this torch?
Perhaps you should learn how to do a proper contact to someone on the forum. @mechanic416 will get his attention. âM416â wonât unless heâs boredâŚ
Thank you for the advise TomWS
But I donât mean any disrespect to mechanic416
Iâm not suggesting you were. I am pointing out that the Forum will automatically notify someone IF you add @ in front of his REAL user name. M416 is meaningless to the forum software.
I donât know. As soon as you type â@mâ youâll get a list of choices - you can select the one you want.
No. Just highlight the one in the popup which starts populating when you type @ followed by a letter or letters. Or type the whole thing in any case and it will correct it when you hit enter.
I think I answered these questions in my last post, but I will do it again.
Yes the iptm60 will work on your plasma cutter and you can get different size cutting tips. Because the torch you have now does not offer different sizes.
Thanks guys for the help
