Wondering if anyone could assist with a LS-THC issue I’m having. After multiple tests I’m getting a live voltage reading of 0.0v.
I checked the wiring 1000 times and even triple checked that the THC chip was installed correctly. All LED’s are illuminated. I even get the torch speed registering when jogging the machine.
I’ve gone through the THC trouble shooting guide a bunch of times and still can’t figure out the problem.
Specs:
-Mac OS with latest drivers and updates
-Tried running torch with Mac laptop plugged to power, and disconnected
-Crossfire pro
-Razorweld Cut45 from Langmuir (plug and play THC)
One thing I noticed when running the Cut45 is I’m not getting any DC voltage at the 50:1 port…
Hoping someone has a solution as I don’t want to start taking the Cut45 apart and I have yet to hear back from support
As Phillip said, the ports may be reversed on the front of the plasm cutter. If you can’t fire the torch by hitting the torch fire button in Firecontrol, that is probably the issue.
Ok. So the ports aren’t reversed. You said you’re not getting any voltage at the divided voltage port on the plasma, while the torch is firing? That would indicate something wrong inside the plasma cutter.
Hi! I have a similar problem. When I try the THC Control test, the Resting THC voltage is 0.0V. In the Live Voltage Test, I push the Torch Fire and I hear a click but no firing.
Manually with pressing the trigger on the handle, I can fire the torch.
I tried to fire the torch after unchecking THC but no firing.
Start with getting the Torch to fire from Firecontrol. One of those ports fires the Torch and the other is divided voltage. If the Torch won’t fire, plug that cable into the other port and try again.
If the other port is reporting high voltage, that can’t be the torch on/off port. The Torch on/off circuit is just closing a circuit. There shouldn’t be high voltage running through that port.
If you hook the torch cable up and it doesn’t fire it probably is in the wrong port. Also if you are not getting voltage on the THC it is probably in the wrong port.
Torch is mounted too low. You are squeezing the plunger inside the torch. Move the bottom clamp up about 2-3 inches. If the plunger inside the torch is stuck it will not fire. Should be able to push the plunger up and have it come back down. Thats how the arc is initiated. No arc No voltage.
Glad you back up and running. Torch is still clamped to low. That whole section of the torch is very weak an eventually damage the torch mechanism.
Good work figuring that out.
