How do I add a stop or pause in sheet cam
G code in between layers for tool change
Add an Operation->Insert Code
Something like:
āM06 (your comment hereā¦)ā
You need to make sure that your Mach3 configuration is set up to enable pause on M6
Heās got a Pro. No Mach3 for him ![]()
Ah, missed that. Does FireControl process M6 in the same way?
M6 - not sure on Pro. Iāve seen M0 - program pause being used by some other folks on Pro.
Check out this post for some info on adding code to sheetcam.
I like how Mach3 deals with the M6 code. Not only does it pause the program, but it, at a minimum, allows you to jog to a new position. But, to me, the best part is that it will run a macro M06somethingsomething (I forget the name at the moment) that I will use to move the gantry to a convenient place to do a ātoolā (AKA nozzle) change and then run another macro when you press Cycle Start. I donāt have an immediate need for the second part, but maybe Iāll discover one once I implement the first.
Now thatās a good question.
It does handle M0 the same in order to get a pause.
Thanks,
No matter to me. I canāt see me going down the CF Pro path⦠2x2 (with indexing) is plenty big enough for me!
I like how things are shaping up with the new Z addition (Crossfire Gets An Upgrade - Floating Z Axis Installed) so Iām not even sure Iāll need the THC mod (depends on how many indexed parts I make, I suspect).
