I uninstalled Fusion and FireControl, then started from scratch, but instead of following the outdated Langmuir videos, I followed other YouTubers’ tutorials. Everything is working great now, except for one issue. I was cutting out pieces similar to a 2-inch washer. I set up 4x4 rows on FireControl to cut out 16 at a time. Initially, it cuts out the first couple of washers perfectly, but then the torch starts to rise slowly, so by the 4th or 5th washer, it’s no longer cutting. Any ideas?
Need more info. Send us all your settings. What did the consumables look like? Did the compressor keep up with the 70 psi of air? Lots of variables. ![]()
With THC on or off when torch started rising ?
Turn off THC and try again.
