Finally got my pro setup. The z axis is plugged in properly. I can not move/jog it at all. It says it’s moving in fire control but does not move/try to move at the machine. I can swap the cable to the x axis port and jog the z axis so I know the motor is good. Any ideas? Is there anyway to cut 2 axis for now like my original machine until I get this figured out??
Can you pull the cover off your electronics box and see if the LEDs on the Z driver are lit up? Also can you check to see that all the wiring between the port and the driver looks good?
Did you ever find a solution? I’m having the same problem and I needed to cut parts before Saturday
I am also having this problem After setup.
