Needing to know an order of things to check as to why my torch [ z-axis] isn’t adjusting while cutting thus cause torch head to bind and or drag. not sure where to start looking to make sure i have the correct firmware loaded so all help welcomed. the machine obviously isn’t sensing material as it pushed it.
Did you solved your live voltage issues from this pervious topic?
I’ve got it cutting. not sure what live voltage parameters are supposed to be. im using fusion 360 with a cut 60 if that info helps. i also got into settings in fusion to see how i have the gcode set up if need that info as well.
