YesWelder CUT-65DS PRO
I’m just trying to figure out if this machine is an okay one to run with until I can afford a higher end one. Is there anyone using this successfully and willing to share cut settings? Link to CUT-65DS PRO
Use the search tool and you’ll find lots of posts related to this cutter. The most notable from a reliable source is this one:
I did see this as well as other not so comments. I’ll be passing on this machine.
If your looking for a low budget plasma cutter I would look at the LOTOS LTP5500D.
@jmccrary81 That is what I have and it’s been fine for my simple needs. Make sure you get the CNC option.
Welcome to The forum. @jmccrary81
This really depends on what you’re going to be cutting.
If you’re cutting a bunch of thick expensive material I would be getting a medium quality or high quality machine to start with.
Wasted material and time adds up quick.
