Yes Welder Cut 65DS
Hello, welcome to the forum. I bought the cut 65 from yes welder and tried it as a hand held unit. I was extremely displeased with it. it would fail to fire about 1/3 of the time, it was super sensitive regarding grounding to the work piece…and i really dont think the output was remotely close to 60 amps either…the fail to fires were unrelated to the ground as it has a pilot arc that is ground independant…when i could get it to fire the ground issue would turn up as failing to transition from pilot amperage to cut amperage. i tried different consumables with no difference in performance. I returned that cutter and went with the everlast 52i. Not as budget friendly as the yes welder but the yes welder was just to flakey to trust on such an expensive investment.
