Wiring Razorweld45 without Voltage Divider for THC
Your plasma cutter has the CNC ports, so why did you tap into the wires inside the plasma cutter?
Because I didn’t want to keep waiting for razorwelds through langmuir. I bought through zoro and I didn’t get the “plug and play” package. Also the voltage divider on my plasma is 20:1 not 50:1
the cables whoulda came with table not the cutter. you should ask Langmuir to send you the cables.
well at least the torch on/off cable with the connector for the front.
Razorweld 45 plug-and-play cables do not come standard with every Langmuir Systems CNC machine. The plug-and-play cables that connect to the ports located on the Razorweld 45 are included in the box that contains the Razorweld 45 plasma cutter.
Our CNC machines include the torch wiring kit that is shown in this step of the assembly process:
https://www.langmuirsystems.com/crossfire/assembly#plasmawiring-section
I have reached out to them for cables and many other things, every time I do they won’t do anything to help. I’m glad they created this forum because you guys have been 100x more helpful.
