Wireless Pendant fix
If you weren’t aware there is a button to change the feed step, I think its Tab will go from cont. to .100 to .010 and so on. it helps with this issue. But pretty sure its inone of the langmuir videos
I could not thank you and a few others enough for the help you have offered.
Disagree. I have returned 4 and still had to pull apart one to make the other work. I still had to buy the ones you suggested to get both machines working. A person should NOT have to spend extra money to make something work that they assumed would work in the first place. I believe that is called theft.
Malfeasance if anything. No property was taken from you, the property just doesn’t work as intended or advertised.
I couldn’t agree more. I bought 1 for the MR-1 and it’s been stellar. Haven’t even had to charge the thing yet after a few months of running parts.
