I am following a cut chart I’ve been using since the start of the original crossfire two years ago (almost) 14 ga
The whole cut does well except for the initial pierce, I have 1 second pierce delay 90 ipm, 35 amps, I even tried 45 amps same deal
seems like too long of a pierce delay. I sped mine up to .5 seconds for 14 gauge
here the thing, i had it at that delay setting of .5 at first, still managed to do this, is it the default settings of the THC?
Are you seeing pierce through before motion happens? If not, then you need to increase the pierce delay.
i will go up to 1.5 and see what happens
Well it’s not the pierce delay, ! It pierces through then I lifts enough to gauged it then cut the rest.
Can you post your g code file here?
should i increase the voltage sample size in the fire control?
Have you taken a look at this, still haven’t figured it out
I’m having a similar problem on 14 gauge but not as bad. Mine leaves a much smaller tab. I can easily bend it to snap it off but it leaves some material that needs to be grinder off. I’m running a Hypertherm 45 XP with 0.4 sec pierce delay at 45 amps and 200 IPM per Hypertherms cut chart. I’m still trying to find the answer to this.
I changed my pierce delay fro 0.4 to 0.6 and it fixed the problem. I’m sure your problem might be different than mine.
(14 ga)
G90 G94
G17
G20
H0
(2D Profile2)
G0 X12.6126 Y5.7789
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
G0 Z0.15 (Pierce Height)
M3
G4 P1.
G0 Z0.063 (Cut Height)
H1
G1 X12.5457 Y5.7268 F80.
G1 X12.5451 Y5.7241 F80.
G1 X13.1445 Y5.7228
G3 X13.3125 Y5.7892 I0.0004 J0.2448
G1 X13.3127 Y5.7894
G3 X13.4024 Y5.9973 I-0.1881 J0.2045
G1 Y5.9977
G1 X13.406 Y7.722
G1 Y7.7222
G3 X13.3433 Y7.9029 I-0.2857 J0.0021
G1 X13.343 Y7.9033
G3 X13.1494 Y7.998 I-0.193 J-0.1491
G1 X13.1493
G1 X12.012 Y8.0004
G1 X12.0138 Y7.9497
G1 X12.056 Y7.9159
G1 X12.0568 Y7.9152
G2 X12.184 Y7.7769 I-0.5453 J-0.6291
G2 X12.2358 Y7.6882 I-0.4133 J-0.3012
G1 X12.236 Y7.688
G2 X12.269 Y7.5799 I-0.4266 J-0.1895
G1 Y7.5798
G3 X12.2905 Y7.4836 I0.9931 J0.1715
G3 X12.3724 Y7.3218 I0.5365 J0.17
G1 X12.3725
G2 X12.6221 Y6.9451 I-4.4664 J-3.2321
G2 X12.6256 Y6.9256 I-0.0235 J-0.0142
G1 X12.5856 Y6.7225
G1 X12.5496 Y6.5381
G1 Y6.538
G1 X12.5281 Y6.4285
G1 X12.5112 Y6.3374
G1 Y6.3373
G3 X12.4945 Y6.2047 I1.1015 J-0.2061
G1 X12.4942 Y6.1698
G1 X12.4973 Y6.142
G3 X12.5276 Y6.0635 I0.2146 J0.0377
G1 X12.5278 Y6.0632
G2 X12.5676 Y5.9574 I-0.2574 J-0.1572
G1 X12.5679 Y5.9547
G1 X12.5711 Y5.9114
G1 Y5.9078
G1 X12.5679 Y5.8527
G1 X12.5678 Y5.8511
G2 X12.5457 Y5.7268 I-1.1164 J0.1341
H0
M5
G0 Z1.
G0 X10.4516 Y5.0481
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X10.4218 Y5.0019 F80.
G3 X10.8109 Y4.8884 I0.3857 J0.5989
G1 X10.8832 Y4.892
G3 X11.2695 Y5.052 I-0.0685 J0.7117
G1 X11.3231 Y5.1006
G3 X11.5342 Y5.6108 I-0.5013 J0.5061
G1 Y5.6111
G3 X11.3707 Y6.0687 I-0.7128 J0.0033
G1 X11.3221 Y6.1224
G3 X10.8118 Y6.3334 I-0.5062 J-0.5013
G1 X10.8116
G3 X10.3539 Y6.1699 I-0.0033 J-0.7128
G1 X10.3003 Y6.1213
G3 X10.0892 Y5.6111 I0.5012 J-0.5062
G1 Y5.6108
G3 X10.2527 Y5.1532 I0.7128 J-0.0033
G1 X10.3014 Y5.0995
G3 X10.4218 Y5.0019 I0.5062 J0.5012
H0
M5
G0 Z1.
G0 X9.1084 Y5.9612
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X9.0917 Y5.9088 F80.
G3 X9.3109 Y5.8753 I0.2157 J0.6789
G1 X9.3831 Y5.8789
G3 X9.7694 Y6.0389 I-0.0685 J0.7117
G1 X9.823 Y6.0875
G3 X10.0341 Y6.5977 I-0.5012 J0.5062
G1 Y6.598
G3 X9.8706 Y7.0556 I-0.7128 J0.0034
G1 X9.822 Y7.1093
G3 X9.3118 Y7.3203 I-0.5061 J-0.5013
G1 X9.3115
G3 X8.8538 Y7.1568 I-0.0033 J-0.7128
G1 X8.8002 Y7.1082
G3 X8.5891 Y6.598 I0.5013 J-0.5062
G1 Y6.5977
G3 X8.7526 Y6.1401 I0.7128 J-0.0033
G1 X8.8013 Y6.0864
G3 X9.0917 Y5.9088 I0.5062 J0.5012
H0
M5
G0 Z1.
G0 X8.012 Y7.1975
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X8.006 Y7.1428 F80.
G3 X8.0871 Y7.1386 I0.0777 J0.7081
G1 X8.1594 Y7.1421
G3 X8.5457 Y7.3021 I-0.0685 J0.7117
G1 X8.5993 Y7.3507
G3 X8.8104 Y7.8609 I-0.5012 J0.5062
G1 Y7.8612
G3 X8.6469 Y8.3188 I-0.7129 J0.0033
G1 X8.5982 Y8.3725
G3 X8.088 Y8.5836 I-0.5061 J-0.5013
G1 X8.0877
G3 X7.6301 Y8.42 I-0.0033 J-0.7128
G1 X7.5764 Y8.3714
G3 X7.3654 Y7.8612 I0.5013 J-0.5061
G1 Y7.8609
G3 X7.5289 Y7.4033 I0.7128 J-0.0033
G1 X7.5775 Y7.3497
G3 X8.006 Y7.1428 I0.5062 J0.5013
H0
M5
G0 Z1.
G0 X6.9223 Y8.5923
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X6.9238 Y8.5373 F80.
G1 X6.9961 Y8.5409
G3 X7.3824 Y8.7009 I-0.0685 J0.7117
G1 X7.436 Y8.7495
G3 X7.6471 Y9.2597 I-0.5012 J0.5062
G1 Y9.26
G3 X7.4835 Y9.7176 I-0.7129 J0.0033
G1 X7.4349 Y9.7713
G3 X6.9247 Y9.9823 I-0.5061 J-0.5013
G1 X6.9244
G3 X6.4668 Y9.8188 I-0.0033 J-0.7128
G1 X6.4131 Y9.7702
G3 X6.2021 Y9.26 I0.5013 J-0.5061
G1 Y9.2597
G3 X6.3656 Y8.8021 I0.7128 J-0.0033
G1 X6.4142 Y8.7484
G3 X6.9238 Y8.5373 I0.5062 J0.5013
H0
M5
G0 Z1.
G0 X5.6421 Y9.7289
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X5.6509 Y9.6747 F80.
G3 X5.9903 Y9.8286 I-0.1154 J0.7057
G1 X6.0439 Y9.8772
G3 X6.255 Y10.3874 I-0.5013 J0.5061
G1 Y10.3876
G3 X6.0915 Y10.8453 I-0.7128 J0.0033
G1 X6.0429 Y10.8989
G3 X5.5326 Y11.11 I-0.5062 J-0.5013
G1 X5.5324
G3 X5.0747 Y10.9465 I-0.0033 J-0.7128
G1 X5.0211 Y10.8979
G3 X4.81 Y10.3877 I0.5012 J-0.5062
G1 Y10.3874
G3 X4.9735 Y9.9297 I0.7128 J-0.0033
G1 X5.0221 Y9.8761
G3 X5.5317 Y9.665 I0.5062 J0.5012
G1 X5.604 Y9.6686
G3 X5.6509 Y9.6747 I-0.0685 J0.7118
H0
M5
G0 Z1.
G0 X4.5768 Y11.0324
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X4.5897 Y10.979 F80.
G3 X4.8769 Y11.1223 I-0.1676 J0.6951
G1 X4.9305 Y11.1709
G3 X5.1416 Y11.6811 I-0.5013 J0.5062
G1 Y11.6814
G3 X4.9781 Y12.1391 I-0.7128 J0.0033
G1 X4.9294 Y12.1927
G3 X4.4192 Y12.4038 I-0.5062 J-0.5012
G1 X4.419
G3 X3.9613 Y12.2403 I-0.0033 J-0.7129
G1 X3.9077 Y12.1916
G3 X3.6966 Y11.6815 I0.5013 J-0.5061
G1 Y11.6812
G3 X3.8601 Y11.2235 I0.7128 J-0.0033
G1 X3.9087 Y11.1699
G3 X4.4183 Y10.9588 I0.5061 J0.5013
G1 X4.4906 Y10.9624
G3 X4.5897 Y10.979 I-0.0685 J0.7117
H0
M5
G0 Z1.
G0 X6.0023 Y12.7843
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X6.0573 Y12.7294 F80.
G1 Y13.195
G3 X5.9907 Y13.3629 I-0.2448 J-0.0001
G1 X5.9905 Y13.3631
G3 X5.7823 Y13.4523 I-0.2041 J-0.1886
G1 X5.7819
G1 X4.0576
G1 X4.0574
G3 X3.8769 Y13.3893 I-0.0015 J-0.2857
G1 X3.8765 Y13.389
G3 X3.7822 Y13.1952 I0.1496 J-0.1927
G1 Y13.195
G1 Y12.7259
G1 X6.0573 Y12.7294
H0
M5
G0 Z1.
G0 X4.536 Y8.5143
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X4.5526 Y8.4619 F80.
G3 X4.791 Y8.5916 I-0.2164 J0.6815
G1 X4.8446 Y8.6402
G3 X5.0557 Y9.1504 I-0.5013 J0.5061
G1 Y9.1507
G3 X4.8922 Y9.6084 I-0.7128 J0.0034
G1 X4.8436 Y9.662
G3 X4.3333 Y9.8731 I-0.5061 J-0.5013
G1 X4.3331
G3 X3.8754 Y9.7096 I-0.0033 J-0.7128
G1 X3.8218 Y9.661
G3 X3.6107 Y9.1507 I0.5013 J-0.5061
G1 Y9.1505
G3 X3.7742 Y8.6928 I0.7128 J-0.0033
G1 X3.8228 Y8.6392
G3 X4.3324 Y8.4281 I0.5062 J0.5012
G1 X4.4047 Y8.4316
G3 X4.5526 Y8.4619 I-0.0685 J0.7118
H0
M5
G0 Z1.
G0 X4.4312 Y6.9107
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X4.4519 Y6.8597 F80.
G3 X4.6373 Y6.9703 I-0.2695 J0.6623
G1 X4.6909 Y7.0189
G3 X4.902 Y7.5291 I-0.5013 J0.5061
G1 Y7.5294
G3 X4.7385 Y7.9871 I-0.7128 J0.0034
G1 X4.6899 Y8.0407
G3 X4.1796 Y8.2518 I-0.5061 J-0.5013
G1 X4.1794
G3 X3.7217 Y8.0882 I-0.0033 J-0.7128
G1 X3.6681 Y8.0396
G3 X3.457 Y7.5294 I0.5013 J-0.5061
G1 Y7.5291
G3 X3.6205 Y7.0715 I0.7129 J-0.0033
G1 X3.6691 Y7.0178
G3 X4.1787 Y6.8067 I0.5062 J0.5012
G1 X4.251 Y6.8103
G3 X4.4519 Y6.8597 I-0.0686 J0.7117
H0
M5
G0 Z1.
G0 X3.7855 Y5.4802
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X3.8149 Y5.4337 F80.
G3 X3.8875 Y5.4862 I-0.3822 J0.6043
G1 X3.9411 Y5.5348
G3 X4.1522 Y6.045 I-0.5012 J0.5062
G1 Y6.0453
G3 X3.9887 Y6.503 I-0.7128 J0.0033
G1 X3.9401 Y6.5566
G3 X3.4299 Y6.7677 I-0.5062 J-0.5012
G1 X3.4296
G3 X2.9719 Y6.6041 I-0.0033 J-0.7128
G1 X2.9183 Y6.5555
G3 X2.7072 Y6.0454 I0.5012 J-0.5061
G1 Y6.0451
G3 X2.8707 Y5.5874 I0.7128 J-0.0034
G1 X2.9194 Y5.5338
G3 X3.429 Y5.3227 I0.5061 J0.5013
G1 X3.5013 Y5.3262
G3 X3.8149 Y5.4337 I-0.0686 J0.7117
H0
M5
G0 Z1.
G0 X7.1219 Y0.7975
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X7.1295 Y0.743 F80.
G3 X7.1812 Y0.7565 I-0.0314 J0.2272
G1 X7.2096 Y0.7707
G3 X7.2733 Y0.8321 I-0.1088 J0.1768
G1 X7.5526 Y1.2612
G3 X7.4334 Y1.2899 I-0.3869 J-1.3451
G1 X7.334 Y1.3067
G1 X7.2289 Y1.3184
G2 X7.2084 Y1.3315 I0.003 J0.0273
G1 X6.7474 Y2.0943
G2 X6.7437 Y2.1047 I0.0235 J0.0142
G1 X6.6598 Y2.6998
G2 X6.5503 Y2.7449 I0.1661 J0.5589
G1 X6.5488 Y2.7458
G1 X6.5041 Y2.7736
G1 X6.5014 Y2.7756
G1 X6.4625 Y2.8068
G1 X6.4612 Y2.808
G2 X6.4158 Y2.8552 I0.3475 J0.3788
G1 X6.4156 Y2.8556
G1 X6.3457 Y2.9411
G1 X6.3447 Y2.9424
G1 X6.2681 Y3.0485
G1 X6.2673 Y3.0496
G1 X6.1779 Y3.1871
G1 X6.1773 Y3.188
G2 X5.9485 Y3.6028 I6.3449 J3.7711
G1 X5.8204 Y3.848
G1 X5.7355 Y4.011
G1 X5.7354 Y4.0112
G3 X5.5978 Y4.2616 I-4.5854 J-2.3566
G1 X5.5376 Y4.3557
G1 X5.505 Y4.3995
G1 X5.479 Y4.4289
G3 X5.4345 Y4.4675 I-0.2022 J-0.1881
G1 X5.4001 Y4.4873
G1 X5.2869 Y4.5345
G1 X5.2847 Y4.5355
G2 X5.1724 Y4.6288 I0.1614 J0.3088
G1 X5.172 Y4.6293
G1 X5.0884 Y4.7406
G1 X5.088 Y4.7412
G3 X5.006 Y4.8453 I-1.1384 J-0.8121
G1 X4.9389 Y4.9198
G3 X4.6748 Y4.9485 I-0.3861 J-2.3257
G1 X4.6747
G3 X4.4292 Y4.9576 I-0.4034 J-7.5662
G1 X4.4291
G1 X4.288 Y4.9609
G1 X4.1618 Y4.9633
G1 X4.0774 Y4.7511
G1 X4.0773 Y4.7509
G2 X3.9248 Y4.4355 I-2.4581 J0.9938
G1 X3.9246 Y4.4351
G2 X3.7517 Y4.1658 I-3.6398 J2.1466
G2 X3.7314 Y4.1541 I-0.0226 J0.0157
G1 X3.1601 Y4.1062
G2 X3.1418 Y4.1113 I-0.0023 J0.0274
G1 X2.5776 Y4.5159
G1 X2.2906 Y4.0749
G3 X2.258 Y3.9577 I0.1773 J-0.1124
G3 X2.2969 Y3.8439 I0.2322 J0.0157
G3 X2.3649 Y3.777 I0.2006 J0.1359
G1 X6.9708 Y0.7794
G1 X6.9711 Y0.7792
G3 X7.1295 Y0.743 I0.127 J0.191
H0
M5
G0 Z1.
G0 X5.7084 Y5.2855
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X5.7237 Y5.2327 F80.
G3 X5.9797 Y5.3678 I-0.1988 J0.6868
G1 X6.0334 Y5.4164
G3 X6.2444 Y5.9266 I-0.5013 J0.5061
G1 Y5.9269
G3 X6.0809 Y6.3845 I-0.7128 J0.0034
G1 X6.0323 Y6.4382
G3 X5.5221 Y6.6492 I-0.5061 J-0.5013
G1 X5.5218
G3 X5.0642 Y6.4857 I-0.0033 J-0.7128
G1 X5.0105 Y6.4371
G3 X4.7994 Y5.9269 I0.5012 J-0.5062
G1 Y5.9266
G3 X4.9629 Y5.469 I0.7129 J-0.0033
G1 X5.0116 Y5.4153
G3 X5.5212 Y5.2042 I0.5062 J0.5012
G1 X5.5934 Y5.2078
G3 X5.7237 Y5.2327 I-0.0686 J0.7117
H0
M5
G0 Z1.
G0 X6.0385 Y7.0657
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X6.0477 Y7.0114 F80.
G3 X6.3832 Y7.1647 I-0.1192 J0.705
G1 X6.4369 Y7.2133
G3 X6.6479 Y7.7235 I-0.5013 J0.5061
G1 Y7.7238
G3 X6.4844 Y8.1814 I-0.7128 J0.0033
G1 X6.4358 Y8.2351
G3 X5.9256 Y8.4462 I-0.5062 J-0.5013
G1 X5.9253
G3 X5.4677 Y8.2826 I-0.0033 J-0.7128
G1 X5.414 Y8.234
G3 X5.2029 Y7.7238 I0.5012 J-0.5062
G1 Y7.7235
G3 X5.3665 Y7.2659 I0.7129 J-0.0033
G1 X5.4151 Y7.2122
G3 X5.9247 Y7.0012 I0.5061 J0.5013
G1 X5.997 Y7.0047
G3 X6.0477 Y7.0114 I-0.0685 J0.7117
H0
M5
G0 Z1.
G0 X7.4275 Y5.4176
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X7.4255 Y5.3626 F80.
G3 X7.4555 Y5.3621 I0.0266 J0.7119
G1 X7.5278 Y5.3657
G3 X7.914 Y5.5257 I-0.0686 J0.7117
G1 X7.9677 Y5.5743
G3 X8.1788 Y6.0845 I-0.5012 J0.5062
G1 Y6.0848
G3 X8.0152 Y6.5425 I-0.7128 J0.0034
G1 X7.9666 Y6.5961
G3 X7.4564 Y6.8071 I-0.5061 J-0.5013
G1 X7.4561
G3 X6.9985 Y6.6436 I-0.0033 J-0.7128
G1 X6.9448 Y6.595
G3 X6.7338 Y6.0848 I0.5013 J-0.5061
G1 Y6.0845
G3 X6.8973 Y5.6269 I0.7128 J-0.0033
G1 X6.9459 Y5.5732
G3 X7.4255 Y5.3626 I0.5062 J0.5013
H0
M5
G0 Z1.
G0 X7.1777 Y3.4828
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X7.1792 Y3.4278 F80.
G1 X7.2514 Y3.4314
G3 X7.6377 Y3.5914 I-0.0685 J0.7117
G1 X7.6913 Y3.64
G3 X7.9024 Y4.1502 I-0.5012 J0.5062
G1 Y4.1505
G3 X7.7389 Y4.6081 I-0.7128 J0.0033
G1 X7.6903 Y4.6618
G3 X7.1801 Y4.8729 I-0.5062 J-0.5012
G1 X7.1798
G3 X6.7222 Y4.7093 I-0.0033 J-0.7129
G1 X6.6685 Y4.6607
G3 X6.4574 Y4.1505 I0.5012 J-0.5062
G1 Y4.1502
G3 X6.6209 Y3.6926 I0.7128 J-0.0034
G1 X6.6696 Y3.6389
G3 X7.1792 Y3.4278 I0.5061 J0.5012
H0
M5
G0 Z1.
G0 X8.8192 Y3.8881
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X8.7982 Y3.8372 F80.
G3 X9.074 Y3.7831 I0.2724 J0.6582
G1 X9.1463 Y3.7867
G3 X9.5326 Y3.9467 I-0.0685 J0.7117
G1 X9.5862 Y3.9953
G3 X9.7973 Y4.5055 I-0.5013 J0.5062
G1 Y4.5058
G3 X9.6337 Y4.9634 I-0.7128 J0.0033
G1 X9.5851 Y5.017
G3 X9.0749 Y5.2281 I-0.5062 J-0.5012
G1 X9.0746
G3 X8.617 Y5.0646 I-0.0033 J-0.7128
G1 X8.5634 Y5.016
G3 X8.3523 Y4.5058 I0.5012 J-0.5062
G1 Y4.5055
G3 X8.5158 Y4.0479 I0.7128 J-0.0033
G1 X8.5644 Y3.9942
G3 X8.7982 Y3.8372 I0.5061 J0.5013
H0
M5
G0 Z1.
G0 X7.2293 Y-0.0423
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X7.2276 Y0.0126 F80.
G2 X7.0505 Y0.062 I-0.0093 J0.3091
G1 X7.0504
G1 X1.6769 Y3.5592
G2 X1.6369 Y3.5903 I0.1468 J0.2297
G1 X1.6357 Y3.5916
G1 X1.6089 Y3.6201
G1 X1.6077 Y3.6215
G2 X1.5599 Y3.7017 I0.2446 J0.2003
G1 X1.5598 Y3.702
G2 X1.5942 Y4.0223 I0.3204 J0.1276
G1 X2.1292 Y4.8444
G2 X1.9936 Y4.9687 I0.9475 J1.1702
G1 X1.9925 Y4.9699
G1 X1.9468 Y5.0235
G1 X1.9458 Y5.0247
G2 X1.8985 Y5.0968 I0.5003 J0.3801
G1 X1.8984 Y5.0969
G2 X1.8611 Y5.1773 I0.5349 J0.2968
G1 X1.861 Y5.1778
G2 X1.8152 Y5.345 I1.06 J0.3803
G1 X1.7819 Y5.5081
G1 X1.742 Y5.6695
G1 X1.7061 Y5.7992
G1 X1.6728 Y5.9126
G1 X1.4497 Y6.0886
G1 X1.4494 Y6.0889
G1 X1.2299 Y6.2679
G1 X1.2296 Y6.2682
G1 X1.0428 Y6.426
G2 X0.7655 Y6.6768 I3.6199 J4.2812
G1 X0.7647 Y6.6776
G1 X0.6766 Y6.7701
G1 X0.6761 Y6.7707
G2 X0.6183 Y6.8418 I0.6652 J0.5993
G1 X0.6177 Y6.8428
G1 X0.5737 Y6.9086
G1 X0.5729 Y6.9099
G1 X0.5033 Y7.0275
G1 X0.5032 Y7.0278
G3 X0.4338 Y7.1259 I-0.5655 J-0.3263
G3 X0.3027 Y7.2254 I-0.3511 J-0.3266
G1 X0.3026
G1 X0.2419 Y7.2568
G1 X0.1421 Y7.3038
G1 X0.0296 Y7.3498
G2 X0.0125 Y7.3762 I0.0104 J0.0255
G1 X0.0323 Y7.9392
G2 X0.0658 Y7.9651 I0.0275 J-0.001
G1 X0.1552 Y7.9451
G1 X0.2558 Y7.9306
G1 X0.4012 Y7.9182
G3 X0.5572 Y7.9128 I0.1843 J3.0677
G1 X0.8123 Y7.9115
G1 X0.9566 Y7.9114
G1 X0.9567
G1 X1.1047 Y7.9105
G1 X1.1051
G1 X1.7173 Y7.8992
G1 X2.0101 Y7.8976
G1 X2.0102
G1 X2.1738 Y7.8966
G1 X2.1741
G1 X2.3909 Y7.893
G1 X2.3912
G1 X2.805 Y7.8809
G1 X2.8054
G1 X3.2564 Y7.8622
G1 X3.2586 Y7.8654
G1 X3.264 Y7.8787
G1 X3.2719 Y7.9107
G3 X3.2811 Y8.0022 I-0.9059 J0.1375
G1 Y8.0023
G1 X3.2844 Y8.0666
G1 X3.2877 Y8.1737
G1 X3.2899 Y8.3414
G1 X3.291 Y8.7077
G1 X3.2901 Y9.1486
G1 X3.2894 Y9.6884
G1 Y9.6886
G1 X3.2923 Y10.3558
G1 Y10.356
G1 X3.2945 Y10.5717
G1 X3.2972 Y10.7873
G1 X3.3003 Y11.003
G1 X3.3038 Y11.2187
G1 X3.3078 Y11.4344
G1 X3.3127 Y11.6705
G1 X3.3183 Y11.9066
G1 X3.3245 Y12.1427
G1 X3.3314 Y12.3788
G1 X3.3388 Y12.6148
G1 Y13.5198
G1 Y13.5201
G2 X3.4472 Y13.7603 I0.3281 J-0.0035
G1 X3.4481 Y13.761
G1 X3.4887 Y13.7946
G1 X3.4918 Y13.7968
G1 X3.5381 Y13.8254
G1 X3.5394 Y13.8262
G2 X3.5982 Y13.8523 I0.1925 J-0.3546
G2 X3.6799 Y13.8743 I0.1838 J-0.519
G1 X3.6801 Y13.8744
G2 X3.7702 Y13.8823 I0.0885 J-0.4874
G1 X6.0981 Y13.8815
G1 X6.1009 Y13.8814
G1 X6.1388 Y13.8775
G1 X6.14 Y13.8773
G2 X6.2172 Y13.8603 I-0.0845 J-0.5671
G1 X6.2176 Y13.8602
G2 X6.2953 Y13.8286 I-0.1475 J-0.4746
G2 X6.3493 Y13.7958 I-0.1717 J-0.3428
G1 X6.3506 Y13.7947
G1 X6.3916 Y13.7608
G1 X6.3925 Y13.7601
G2 X6.5007 Y13.5201 I-0.2194 J-0.2433
G1 Y13.5198
G1 Y10.7435
G3 X6.5234 Y10.6416 I0.4366 J0.0439
G1 X6.5381 Y10.6081
G1 X6.5552 Y10.5797
G3 X6.6124 Y10.5203 I0.2235 J0.1579
G1 X6.6126 Y10.5201
G3 X6.6558 Y10.4911 I0.2191 J0.2802
G1 X6.6563 Y10.4908
G3 X6.8558 Y10.4444 I0.1723 J0.2881
G3 X7.0275 Y10.5011 I-0.0422 J0.4156
G2 X7.064 Y10.4934 I0.0141 J-0.0236
G1 X7.289 Y10.1766
G1 X7.4018 Y10.163
G1 X7.4026 Y10.1629
G2 X7.6477 Y10.1162 I-0.4859 J-3.2191
G1 X7.6481 Y10.1161
G3 X7.7878 Y10.1067 I0.0967 J0.3911
G3 X7.8971 Y10.1423 I-0.0771 J0.4218
G1 X7.8976 Y10.1426
G2 X7.9669 Y10.1692 I0.2489 J-0.5431
G1 X7.9679 Y10.1695
G1 X7.9828 Y10.1736
G1 X7.9845 Y10.174
G2 X8.0392 Y10.1742 I0.0278 J-0.1363
G1 X8.0396 Y10.1741
G2 X8.0815 Y10.1564 I-0.0249 J-0.1176
G2 X8.1251 Y10.1205 I-0.1076 J-0.1752
G1 X8.1253 Y10.1203
G3 X8.2169 Y10.0281 I1.0044 J0.9059
G3 X8.2639 Y9.9952 I0.2011 J0.2367
G3 X8.308 Y9.9822 I0.0545 J0.1039
G3 X8.3605 Y9.9932 I0.0003 J0.1293
G1 X8.4232 Y10.0218
G2 X8.5021 Y10.0275 I0.0471 J-0.103
G1 X8.5306 Y10.02
G1 X8.5976 Y10.0045
G1 X8.6863 Y9.99
G1 X8.8217 Y9.9757
G3 X9.1337 Y9.9693 I0.2204 J3.1511
G1 X9.1339
G2 X9.2762 Y9.9644 I0.027 J-1.2804
G1 X9.2784 Y9.9641
G1 X9.3315 Y9.9549
G1 X9.3334 Y9.9545
G2 X9.4231 Y9.9199 I-0.0932 J-0.3751
G1 X9.4235 Y9.9197
G2 X9.5725 Y9.8309 I-1.5617 J-2.7898
G1 X10.5293 Y10.1115
G2 X10.5506 Y10.1091 I0.0077 J-0.0264
G1 X10.7009 Y10.0244
G3 X10.9994 Y9.867 I3.7835 J6.815
G1 X10.9995
G3 X11.2928 Y9.7482 I0.8692 J1.7243
G3 X11.433 Y9.7129 I0.403 J1.3067
G3 X11.5448 Y9.7008 I0.1275 J0.654
G3 X11.8543 Y9.7383 I-0.0048 J1.3379
G2 X11.8881 Y9.7147 I0.0065 J-0.0267
G2 X11.9412 Y9.1873 I-18.1346 J-2.0913
G2 X11.9759 Y8.727 I-25.9649 J-2.1879
G1 Y8.7268
G1 X11.9874 Y8.5385
G1 X11.9875 Y8.5383
G1 X11.9924 Y8.4438
G1 X13.475 Y8.4407
G1 X13.4753
G2 X13.7152 Y8.3318 I-0.0042 J-0.328
G1 X13.716 Y8.3309
G1 X13.7495 Y8.2902
G1 X13.7516 Y8.2871
G1 X13.7802 Y8.2408
G1 X13.781 Y8.2394
G2 X13.8069 Y8.1805 I-0.3551 J-0.1917
G2 X13.8288 Y8.0988 I-0.5192 J-0.183
G1 X13.8289 Y8.0986
G2 X13.8366 Y8.0085 I-0.4876 J-0.0873
G1 X13.8308 Y5.6806
G1 X13.8307 Y5.6778
G1 X13.8267 Y5.6399
G1 X13.8266 Y5.6387
G2 X13.8094 Y5.5616 I-0.5668 J0.0857
G1 X13.8093 Y5.5612
G2 X13.7776 Y5.4836 I-0.4743 J0.1483
G2 X13.7446 Y5.4296 I-0.3425 J0.1724
G1 X13.7436 Y5.4283
G1 X13.7096 Y5.3874
G1 X13.7088 Y5.3865
G2 X13.4686 Y5.2788 I-0.2429 J0.22
G1 X13.4683
G1 X12.4289 Y5.281
G2 X12.4095 Y5.2202 I-0.2504 J0.0468
G2 X12.3359 Y5.1167 I-0.2593 J0.1063
G1 X12.3334 Y5.1147
G1 X12.3011 Y5.0921
G1 X12.2996 Y5.0911
G2 X12.2158 Y5.0551 I-0.1714 J0.283
G1 X12.2156
G2 X12.0528 Y5.0179 I-0.5655 J2.102
G3 X11.8971 Y4.9809 I0.3109 J-1.6538
G1 X11.897 Y4.9808
G3 X11.6655 Y4.8811 I0.2731 J-0.9525
G1 X11.6654 Y4.881
G3 X11.5454 Y4.8019 I0.656 J-1.1247
G1 Y4.8018
G3 X11.3931 Y4.6792 I1.3183 J-1.7917
G3 X11.2594 Y4.5511 I1.6422 J-1.8489
G1 X11.2592 Y4.5509
G3 X11.1993 Y4.4835 I0.6208 J-0.6118
G3 X11.0803 Y4.3223 I3.0707 J-2.3918
G1 X11.0802 Y4.3222
G2 X10.9922 Y4.2263 I-0.4164 J0.2939
G1 X10.9897 Y4.2244
G1 X10.9441 Y4.194
G1 X10.9422 Y4.1929
G1 X10.9403 Y4.1919
G1 X10.7387 Y4.0994
G3 X10.5094 Y3.9771 I1.8009 J-3.653
G1 X10.3709 Y3.8963
G1 X10.1955 Y3.789
G1 X9.8916 Y3.5937
G3 X9.5667 Y3.373 I7.6879 J-11.6673
G3 X9.4179 Y3.0585 I4.9068 J-2.5132
G1 X9.4178 Y3.0582
G3 X9.2453 Y2.5727 I3.0295 J-1.3502
G3 X9.2188 Y2.4394 I0.9864 J-0.2649
G1 X9.216 Y2.3897
G3 X9.2328 Y2.2802 I0.489 J0.019
G1 X9.2334 Y2.2774
G1 X9.2464 Y2.1979
G1 X9.2575 Y2.1395
G1 X9.2738 Y2.0704
G1 X9.2997 Y1.9734
G1 X9.3441 Y1.8215
G1 X9.4489 Y1.4775
G1 X9.5726 Y1.0866
G2 X9.564 Y1.0571 I-0.0262 J-0.0083
G1 X9.1123 Y0.6814
G2 X9.0782 Y0.6806 I-0.0176 J0.0211
G3 X8.9886 Y0.7422 I-0.7897 J-1.0528
G1 X8.9885
G3 X8.8911 Y0.7975 I-0.6516 J-1.0358
G3 X8.7766 Y0.8499 I-0.7276 J-1.4384
G3 X8.501 Y0.9418 I-0.8795 J-2.1784
G1 X8.5008
G1 X8.2038 Y1.0238
G1 X8.2033 Y1.0239
G1 X8.0835 Y1.0595
G1 X7.5071 Y0.1739
G2 X7.4723 Y0.1282 I-0.3091 J0.1997
G1 X7.4722 Y0.1281
G2 X7.4303 Y0.0886 I-0.2615 J0.2356
G2 X7.2278 Y0.0126 I-0.2155 J0.2666
G1 X7.2276
H0
M5
G0 Z1.
G0 X7.8596 Y1.7853
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X7.8408 Y1.7336 F80.
G3 X8.0871 Y1.6909 I0.2428 J0.6697
G1 X8.1594 Y1.6945
G3 X8.5457 Y1.8545 I-0.0685 J0.7117
G1 X8.5993 Y1.9031
G3 X8.8104 Y2.4132 I-0.5012 J0.5062
G1 Y2.4135
G3 X8.6469 Y2.8712 I-0.7129 J0.0033
G1 X8.5982 Y2.9248
G3 X8.088 Y3.1359 I-0.5061 J-0.5012
G1 X8.0877
G3 X7.6301 Y2.9724 I-0.0033 J-0.7128
G1 X7.5764 Y2.9238
G3 X7.3654 Y2.4136 I0.5013 J-0.5061
G1 Y2.4133
G3 X7.5289 Y1.9556 I0.7128 J-0.0033
G1 X7.5775 Y1.902
G3 X7.8408 Y1.7336 I0.5061 J0.5013
H0
M5
G0 Z1.
G0 X10.7805 Y6.8729
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X10.7552 Y6.8242 F80.
G3 X11.0873 Y6.7438 I0.3287 J0.632
G1 X11.1596 Y6.7474
G3 X11.5458 Y6.9074 I-0.0686 J0.7117
G1 X11.5994 Y6.956
G3 X11.8105 Y7.4661 I-0.5012 J0.5062
G1 Y7.4664
G3 X11.647 Y7.9241 I-0.7128 J0.0034
G1 X11.5984 Y7.9777
G3 X11.0882 Y8.1888 I-0.5061 J-0.5013
G1 X11.0879
G3 X10.6303 Y8.0253 I-0.0033 J-0.7128
G1 X10.5766 Y7.9767
G3 X10.3655 Y7.4665 I0.5013 J-0.5062
G1 Y7.4662
G3 X10.5291 Y7.0085 I0.7128 J-0.0033
G1 X10.5777 Y6.9549
G3 X10.7552 Y6.8242 I0.5062 J0.5012
H0
M5
G0 Z1.
G0 X9.6668 Y7.9726
G92 Z0.
G38.2 Z-5. F100.
G92 Z0.
G0 Z0.3
G38.2 Z-5. F5.
G92 Z0.
G92 Z0.
M3
G4 P1.
H1
G1 X9.6506 Y7.9201 F80.
G3 X9.8635 Y7.8886 I0.2094 J0.6809
G1 X9.9358 Y7.8922
G3 X10.3221 Y8.0521 I-0.0685 J0.7117
G1 X10.3757 Y8.1008
G3 X10.5868 Y8.6109 I-0.5012 J0.5062
G1 Y8.6112
G3 X10.4233 Y9.0689 I-0.7129 J0.0033
G1 X10.3746 Y9.1225
G3 X9.8644 Y9.3336 I-0.5061 J-0.5013
G1 X9.8642
G3 X9.4065 Y9.1701 I-0.0034 J-0.7128
G1 X9.3528 Y9.1215
G3 X9.1418 Y8.6113 I0.5013 J-0.5061
G1 Y8.611
G3 X9.3053 Y8.1533 I0.7128 J-0.0033
G1 X9.3539 Y8.0997
G3 X9.6506 Y7.9201 I0.5062 J0.5013
H0
M5
G0 Z1.
M30
(PS80)
