Waterproof Cover
Definitely possible. It’s gonna be heavy when full of water. If you drain it, relatively easy.
You’ll need a good rolling base, a smooth transition to the outdoors, a shelf under if you plasma will also go out (or wall mount), etc. However, be aware you might have problems getting out of square if you go jostling it around to much.
Pimp My Pro- Mods and Addons - CrossFire ® PRO - Langmuir Systems Forum
I’d get a nutsert tool and add some eyelets to the tray rails to attach a tarp. The arm for the torch routing would actually make a nice tent pole.
I have this one and it works great:
Amazon.com: Astro Pneumatic Tool 1442 13" Hand Rivet Nut Setter Kit - Metric & SAE W/ 60pc Rivnuts : Tools & Home Improvement
