I see people draining into plastic tank with a pump.
Do you refill table with same water that was drained?
How does the water get cleaned?
Since I have a few weeks until Pro arrives, i want to get this stuff figured out
Most of them have either a scotchbrite pad at the drain or have an inline filter similar to what you would use on a sprinkler system or tank sprayers. Others just let the sediment settle to the bottom.
@toolboy has a couple of posts that detail the filter he used.
I just let mine settle for a few days before I drain it. Then it stays in the container and settles more before it gets pumped back into the table.
Don’t worry about clean water. Once you clean out your table the first time, you’ll understand that keeping the water clean is impossible. Just let the junk settle to the bottom, drain it and scoop out all the sludge and pieces of scrap.
I just waited until I drained mine and let it settle in buckets while I cleaned the slats. When I refilled it I left the bottom inch in each bucket.
I use gravity to drain my table and it flows through a residential water filter known as a Rainbird water filter…then into the storage tank…after 3 years I have zero sludge and no extra wear on my pump system.
Can i see a pic?
