Water table fluid
toolboy,
I bought a 20 gal vertical fuel tank and modified it like the pictures. Table will hold 17 gallons as far as usable level is concerned. The tank was $ 139 on speedway.com. I use a 4 gallon per minute 120 volt pump to fill and gravity to drain it. A three way valve from McMaster carr it directs the flow. Nice fill rate, it doesn’t shoot out of the drains very crazy. Bubbles up about 1 inch or so. fills table in 3 or 4 min.
