For the engineers at Langmuir - how much water is recommended?
@DougDuvall welcome to the forums
If you want to talk to the people from Langmuir you’ll have to add them to the conversation.
Hey Doug,
Hope you had a great weekend!
The water level should be about 3/4" below the top of the slats.
Does anyone know the volume of water for the PRO table I bought a 16 gallon reservoir to drain into and refill will that be enough.
I believe the pro holds exactly 16 gallons if it’s completely full.
So likely about 12 to 14 gallons for its normal operating depth.
HI. The estimated answer is 15 gallons.
Here is how I go there: 36" x 48" x 2" = 3456 cubic inches.
1 cubic inch = 0.0043 gallons.
Add a little for “wiggle room”.
And TinWhisperer beat me to it!
Thanks for the input. Just wanted to make sure I had enough room to drain it.
Thanks also for the quick response.
