Hi ladies and gents,
I relocated my plasma cutter to the wall. Question about wiring.
Did you guys extend your THC/plasma on/off wiring?
(As the wiring is short to begin with)
Or did you relocate the whole electronic enclosure and just extend the x-axis dsub cable?
Thanks!
I only extended my x axis cable to mount my electronics enclosure to the wall.
The electronics enclosure is behind the monitor mounted to the wall.
This picture is older. The set up looks a little different now.
              Awesome thanks Tin! Yeah I found some straight through DB9 online… less messing around.
-IF
