Using Crossfire in Europe
Has anybody in Europe received their Crossfire yet? Mine is inbound next week and I started lookingintohow to connect it to our power sources.
Initially I was planning to use a 230 volt to 110 volt transformator. Looking at the specs for the Crossfire I noticed that it can be run on 220 volt.
Anybody know if it will run on our 230 volt 50Hz?
@DannyD The CrossFire PRO electronics can run on 230V/50hz. When you are installing the electronics cover onto the unit, you need to make sure to first switch the toggle on the side of the power supply from 110 to 220. You will need to do this before first powering up the unit!
Yes It will operate on the 230V/50Hz standard European voltage thanks!
Awesome! You guys are the best! Think of everything seems to be your middle name!
Thanks,
D
