Has anyone experienced the upper reference edge deviation sticker missing the +/- mark? Mine is missing the MID reference mark. If I put in a positive the calculator calls for 1 shim in the bottom. If it is negative then I don’t need any shims. Not sure what is best to do in this case or will it not really matter in the long run as I will have to tram it later. Thank you for your help.
Jeff
