So my machine is within an 1½" of the wall. So I still wanted to be able to remove the plex if something got behind it. I used weld nuts on the outside of the enclosure and 3d printed washers for the plex side. Using rivnuts would work but would also require a much larger hole in the enclosure panel. So if I ever move out of my small garage and wanted to change it later I’d have to use giant washers to cover the holes.
Nice mod thanks for sharing! That should work well for you.
Mine will have to be in the corner as well. I love the idea! can we get a source for those weld in nuts? else I was looking at possibly using U clips for automotive fenders. i will have to look at things more closely once my machine arrives.
You can get them from McMaster Carr.
