I just has a problem with my 45xp on the Pro table. It would cut for about 6 inches then stop. I kind of acted like ground wasn’t connected so I checked and that wasn’t it. I tried a few different things and finally decided to look at the front of the 45xp and the air LED was lit. I discovered my air pressure was fractionally too low. It was enough to start the cut but apparently dropped as it went. I turned up the air to be sure it was comfortably higher than 90 PSI and the problem was solved.
