The only times it has frozen WITH the torch firing was for the brief moment that I had the torch and work clamp leads connected to each other with zip ties. Typically it will freeze well into a cut; often near the very end of the cut, in the now dozens (hundreds?) of straight line tests I have performed.
Yes, both the Langmuir support person, Thomas, and Gene with Primeweld have told me repeatedly that there is no point in wiring to raw voltage, and that divided voltage is not causing FireControl to freeze. Thomas has said that there’s not any evidence to suggest divided voltage isn’t working exactly as it should be, and that voltage signal to FireControl has not historically caused interference or freezing for other users.
I should say that both of them seem fairly invested in my figuring the issues out. Thomas has spent hours on my issues, and I’m sure he’s not cheap for Langmuir (I get the impression that he is an independent consultant). Gene just kind of seems like he doesn’t want to send me a THIRD plasma cutter, but at the same time like he probably would if I leaned on him a little.
