My Crossfire PRO has been functional for several months now.
While I was performing the periodic check that the bolts and nuts are tight, I removed the torch mount and checked if it was perfectly perpendicular. I believe I am a bit off now, I started playing with the screws but didn’t have a good feeling.
What is the correct procedure to tram with a fully build machine? Should I loosen the X-axis lead nut assembly before I do the procedure documented at Tramming the Z-axis Slide on the CrossFire PRO CNC Plasma - YouTube ???
