I was unscrewing my touch probe after using it, and didnt realize that the probe wasnt unscrewing, it was unscrewing the 2 halfs of the connector. It seemed a bit tight, but nothing crazy. When it came apart I realized what had happened. Does anyone know what wires go to which pins? I guess Ill try and re-strip them and re-solder them on.
Couldnt find any threads with this info, so I assume Im the first person dumb enough to do this. Once its fixed, there will be loctite going on the connector side.
Went and took apart the other end of the connector. I assume its the same on both ends so it goes
1: yellow
2: orange
3: brown
In case this comes up for anyone else.
Edit, I lied. Apparently matching the incoming wires dont work. I get a light on the probe, but it wont light up the “probe” icon on Cut Control. I hope its just a wiring issue and something isnt broken in the probe.
Edit Edit: I re-soldered the whole thing and it works now. So those colors are right.
I took apart my two probes this morning for you. Both of mine are the same as Alex’s.
Pin 1 White
Pin 2 Black
Pin 3 Red
Sorry, I could not be of any help.
BigDaddy, Perfect timing and thanks for this. I needed exactly that after recently running my spindle warmup AFTER mounting my touch probe… ill-advised
The real tragedy is that it really wouldn’t have been hard to add another pin to the probe that checks for continuity that would occur when the probe is plugged in and refuse to start the spindle.
