My touch probe is slightly off every time I probe an edge. I have meticulously set travel compensations using 2 different dial indicators, it is set perfect. I have also set the touch probe concentricity to where the dial indicators do not budge as its rotated in the collet. BUT, for some reason when I use the probe to find the 3" edges of the 123 block it comes up .0047" long on X and .0048 long on Y. I did have to update my probe with the 2.0 kit. Is it possible something is off inside or is this as accurate as the probe gets?
I was looking over my notes while measuring and made a mistake in my initial post. I was at .0048" UNDER on Y and .0047" UNDER on X measuring the 3" block. When setting deflection to 0, I am .009" UNDER on Y and .0096" UNDER on X measuring the same 3" block. I also managed to catch an edge of the 123 block with the stylus and break it. Is it possible to order just the stylus?
On another note…
It would be cool if there was a setting where if you’re jogging the machine manually and then catch an edge with the probe it stopped it like a limit switch instead of just powering through.
