Torch trigger cable
bought the razerweld45 with my pro table and THC .Says its plug and play with no wiring inside the box cant find the torch firing cable that plugs into the THc and into the main control box. I do see 2 loose connectors one that has a 2 pic config and another that is3. do I need to solder the 2 pin connector to the 2 wire that has the plug for the trigger on the box? guy on youtube had the wire and correct plugs anready made in his razerweld 45 box. Dont see anything about soldering cables the make the razerweld plasma cutter trigger work!!
Pictures of what you have?
Bought it new? Used?
If new, items are found between multiple boxes and will be labeled.
The torch on/off cable is in a separate box (in a bag) from your THC setup.
thanks I will go back thru all the cable bags and make sure I have one.
