Torch not moving
so I’m having issues, my torch is not moving. I tried to home it,but it still will not move. any ideas?
Not moving as in…motors turn but no physical movement? Motors don’t turn? Ensuring your keyboard or whatever you’re using to jog works? Not moving in a specific direction, or all directions? Control panel plugged in and turned on?
You’re leaving way too much out for us to guess.
Assume you have limit switches; rip them out you don’t need them on such a small table.
If the motors don’t move at all, the first thing to check is the control box power.
  1. Is the control box powered on?
  2. If the box is powered on, check the DC voltage output from the power supply inside the control box.
The DC power supply should be putting out 36v DC when measured at the DC + & - terminals.
If it’s not putting out 36v, it needs to be replaced.
Thanks… I figured out what was happening.
I have new problem.
And that problem was…
Please post solutions so that others reading that may have the same issue will know what to check.
