Tonight while I was cutting some parts I started getting the “Torch Moving Before Voltage Sensed” error. I have discovered that I’m no longer getting voltage during cutting. I’ve only cut maybe 20 parts, so far no other issues.
I’m using a PrimeWeld Cut60 (updated with the cnc plug in the top right). I was using the divided voltage, I tried soldering the raw voltage leads on and there was no change at all.
When I do the THC Health Check, I get 0V on the live voltage reading.
I went through the whole troubleshooting guide, I’m not entirely sure about the step circled in red:
When I leave the usb and work clamp plugged in, I’m getting about 2000 ohms resistance, when I disconnect the work clamp, it is discontinuous. I’m not sure if this reading would be considered “less than 10,000 ohms” or not?
Rather frustrated as I had a day of cutting planned for a project tomorrow. Any assistance would be greatly appreciated.
