Torch dragging on metal (PSA?)
There has been at least three separate individuals in the last month post that their torch was dragging on the metal while they were cutting and the torch failed to lift up the one inch after each cut. If what I am about to describe sounds like your scenario, I would urge you to recheck your actual cut height.
Back story (Quick version): My cut height was way off. When it was CAM’d for 0.06 I was getting 0.095. I made some major adjustments with my proposed cut height (0.021) and springback (-0.02) and this achieved a cut height of 0.060. My cuts were never better: minimal to no dross and minimal to no bevel.
That same situation continued for more than a year, although I don’t do a lot of cutting.
Earlier this year, I began having the very issue of the torch dragging on the metal, moving it out of place and not returning to a reasonable height during rapids nor at the end of the program. I was not realizing inferior cuts because I was using “Nominal Voltage” with the THC. As you probably know, ‘Nominal Voltage’ does not care what the height is. It will put the torch at the height that achieves the correct voltage you set. This is why my cut quality did not show a problem.
I finally did Phillips cut height test again. The same one that resulted in the 0.095 before.
It was now registering dead-on at 0.060 so I changed my post-processing with cut height of 0.060 and left the spring back at -0.02 since I was cutting .25 inch steel.
Results: Cuts were perfect, no dragging on the metal and torch lifted up one inch at the end of the program.
So if your torch is dragging and not returning to 1 inch height consider re-running Phillips cut height test.
Note: I wrote “PSA?” as this might need to be a Public Service Announcement to anyone who may have followed my advice in the past and is now having the issues outlined. :wink:
i may run this to see where im at, i had a sheet of 18g get dragged from my machine not lifting only had the issue once but thats definetly all it takes to get infuriated hahahaha
hurray!!
my FC height test works great as a test.
ive ruined more tips than ild like to admit and its still gets half way through an out side contour and drags.
I am more confused the more i read
Is there a question? You might want to start a new topic and describe what is going on. Don’t spare the detail. Show photos of your setup and supply some recent cut files.
It sounds like you might have some EMI issues if your cut height is correct but you are having intermittant problems.
I finally turned off the THC to get some work done. The topics seem to run into so many other things and acronyms dont help much if i dont know what they mean.
I have a razorcut 45. Everything is stock from the company. It was working fine when i left it a week ago and now it wont cut anything.
I seem to remember reading the Torch Height Control has issues with connections? I always have to wiggle all the connectors to even get it to go.
I am not sure even what to ask. I am sorry to have wasted your time!
Cant add anything until i get back to my machine ~ ill be on the road for at least a week now.
Thanks for replying. I was/am very frustrated!!
That is true for most of us. Don’t worry.
EMI stands for Electronic Magnetic Interference. If that is the issue, it can be an easy fix or a very convoluted issue.
And it is not wasting my time. I hope I didn’t come across that way.
Since you have the RazorCut, I would say a common thing that happens is that the internal air pressure regulator in that unit, will malfunction.
The reason I suggested a new thread/topic for your issue is because you might get more attention on that thread. Lots of great minds on this forum and they are not likely to look at an old thread like mine.
Touch back in when you are back in town.
