has anyone had this problem ?
the torch start good but then the THC raises the torch as it start cutting,
i on a Crossfire PRO using fire control and a Powermax 45 XP plasma. i’ve made thousands of cuts with no problems. i tried another G-code and also a straight cut in fire control with all having the same problem.
voltage test all tested Good. 127.2 volts
This sounds basic… but happened to me. I thought I entered 0.06 for cut height in sheetcam… accidentally had 0.6… didn’t catch it and torch would initial sense, start to move up to 0.6 while it starts to proceed with cut… LOOSES arc at height after pilot kicks out.
It’s not really contacts. The only contacts are on the IHS switch and that is either an open or closed thing, so it either works or it doesn’t. The thing that they are cleaning is the wheels that ride on the rods in the Z-axis. There is a plastic isolator that is supposed to prevent a ground loop from occurring between the IHS wiring and the frame of the machine. Metal dust can get in there and complete the loop, causing phantom voltage to be reported to the THC. Blowing it out with compressed air seems to help.
