Everlast 52i plasma cutter
Cross Fire Pro
Just received table 2 weeks ago. Upon opening the electronics control box for installation it was noted the torch control relay was not installed into the board and was rattling around inside the control case.
Installed relay per the notes of the assy. manual.
assembled electrical connection from CNC port of the plasma cutter to the control box on the table, OHM checked to verify wiring is correct.
Upon starting up the fire control software and the plasma table the torch will fire continuously until the plasma cutter goes into an error mode.
I have checked to operation of the plasma cutter with torch fire control disconnected and the plasma cutter operates normal.
As soon as you plug on the torch control (on-off) plug into the table control box the torch will start and fire continuously, unplug and the torch stops.
Everything up to the CNC table control box rings out correctly.
Not sure if this is a fire control relay issue or an issue somewhere else in the control box.
