Hey guys, I’ve had my table for two months and it worked great. Now its started to have the torch always on. If I turn on the box on the table the torch is on. The handheld trigger works normal if the torch cable is unplugged from the box. I’ve tested the cutter and it seems ok. If I let the torch be on it makes the holder move to the X+ axis. Any ideas? I have things to cut so I’m a little impatient
the torch relay is stuck is my guess i would contact ls support.
Ok I have tried to remove the relay and it shut the torch off. I’m guessing there’s no way to fix it if it’s bad?
i would assume not. after moving it didn’t jar it loose. if you contact ls they usually ship out warranty part very fast.
