Tool setter with fly cutter
How are you guys with the tool setter touching off fly cutters?
I do it manually with a piece of paper.
Right on, thanks
or you could temporary offset the location of the tool setter and let the insert coincide with the tool setter surface. Once done then re-enter the previous tool setter coordinate.
My setter X position is at 19.4"; i just edit the position quick to 18.4" then run the tool settee routine. Switch it back to 19.4" for regular tools.
