i could use some help . i am trying to make my tip life last longer. i believe i may be shorting the life of the tips. i am running a job right now of a 176 parts and i only finished 90 parts on 1/8 steel. in this event i used (2) 45 amp hypertherm sync 45 tips . thank you for the help
settings
130 ipm
delay of .5
80psi at the table
my air set up is a 175 psi 14.7 cfm at 90 psi . piping goes 3/4>3/8 at cutter.
i have 3 dryers 1 industrial air dryer and 2 silica orb dryers
I realized that Hypertherm is by far the best. But the new sync consumables at $45+ each are crazy, with the list of things you have to do to protect them from moisture, and still wear out. Unless you have an extreme water issue causing this. I would rethink buying one for myself anytime soon. Let the Hypertherm hate mail commence. I’m ready to read your success stories. You have to admit that this whole sync thing is a corporate idea to force OEM consumables down consumers’ throats.
i have had my crossfire pro up and running sense Christmas. i have had more problems the i will like .i don’t know if it my cutter or my crossfire pro. but it will randomly stop cutting . i redid my whole air system replaced the motion bord, thc cables langmuir sent me
I could cut all that (referring to what’s pictured) with one set of consumables on my 45xp. Something is wrong. Only way to tell is with pictures of your cuts, need to know your live voltage numbers while you’re cutting (if you have THC), and more detailed information on what your air setup is. Pictures are always best.
Good. The next question is, are you using a laptop? Is it plugged into the charger while you’re cutting? This has nothing to do with the consumables wearing out. Like @brownfox said take a screenshot when it happens and let us know the voltage reading while cutting.
Next time, try without the laptop plugged into the wall. That will sometimes make a ground loop. That all looks great. It looks like you have done your homework. Another question, work clamp on the metal you’re cutting? These are just flow sheet questions that need clarity
