I’ve had my MR-1 for a couple of weeks and am now attempting threadmilling. I’m trying to mill 1/4"-20 into aluminum. I’m only using parts from langmuir, so that’s the LSTM-4fl180-750-NONVAR thread mill with a 13/64" stub bit for the pilot hole. Does that sound right?
I guess it would depend if it is a blind hole, or a through hole. If it’s a through hole, hand tap, (or power tap with a drill press or knee mill if thread forming).
I guess it depends on the class of fit. HSMAdvisor shows a minor diameter of .19587" for a 1/4-20 internal thread. I measured the minor diameter of a 1/4-20 nut and i get .2085. A 13/64" should be fine. If it seems loose try a #7 drill.
