1.5 minutes to fill and approximately 3.5 to drain. A very small amount of water is left in the pan, as drain holes still aren’t 100 percent the very lowest point (really wish I could tig stainless and put one of those sump mods like I’ve seen here) but I am going to use a wet vac to clean the table after each use, so shouldn’t be too big of a problem.
Which brings us to wire management and drag chains. I really like the aluminum channel capturing the drag chains modification, but alas I don’t have any aluminum in my pile o’ stuff so I thought I would try it without and just use some custom brackets for attachment.
Drilled holes in some small pieces of plate and welded tiny bolts in place
Cobbled together some more bracketry to weld those to. In efforts to keep the table relatively clean by not drilling a bunch of extra holes, I’m trying utilize what’s existing as much as possible.
Which brings me up to date where I’m at today, which should be ready to start test cutting. (still need to permanently mount the computer and do some final wiring clean-up)
