THC upgrade Miller Spectrum 375 wiring
Installing the Z axis and the new equipment was pretty straight forward following the instructions. Where the problem lies is wiring for a lack of better words. I followed what instructions they had but It would fire and not continue to run.
Per the support tech he Miller 375 Spectrum doesn’t have divided voltage and you have to use the raw voltage. Attached are a few photos to show the wiring.
Great news Jack and thanks for sharing your knowledge… Undoubtedly, something that can be used in the future!! Happy Cutting!!!
So is this correct I have found multiple threads on this forum that show the polarity opposite of what’s shown in this photo.
so for the 625 your answer is yes or no ?
Lug TE-3 (middle) from the diagram is hook to the red positive terminal
Lug TE-4 (right) from is hooked to the black negative wire terminal
The picture above does show the opposite to that so I assume its wrong. ? look like the op endded up using a different plasma cutter after this post.
a plasma cutter is a constant current electrode negative power supply .
if you did get the polarity mixed up you could always swap the leads at the VIM.
If it is KNOWN that the photo in the original post is wrong, it should be flagged as such, either remove the photo or put some BIG text in that post. From your schematic and Tin’s comment RE lugs, I would say it is wrong.
Maybe I’ll pull open my 375 again and triple check it?
if @jFab could follow up on his experience with the 375 would be helpful but from his activity history he move to a different plasma cutter short after the post above. .
Maybe the the pic is of a 625x not the 375 ? Looking at the wiring diagram included with the 625 the terminal on the right is the work/clamp which I believe is pos and the terminal in the middle is the torch which is neg unless I am reading the wiring diagram wrong.
I only have a 375 so I can’t physically verify for the 625
When I look at the wiring diagrams for each power supply they seem virtually identical.
This is a screenshot from the 625 manual wiring diagram.
Here’s another link from that same topic with a customer who successfully wired his Miller to run with the THC it has some pretty clear photos
Here’s a good tidbit on some of the machines those lugs are reversed…
Of course why would you want the terminals in 2 3 4 order when you could have them in 2 4 3 order, thanks miller?
Here is a pic of mine, you can see the bundle from the center terminal (all marked 20) run directly to the torch.
And you can see on mine that they swapped those terminals.
Mine has the ice 27 torch on it. Which sticks into the cabinet longer so there’s a little bit more wire when they move to the bigger torch it looks like it doesn’t stick into the cabinet as much and have shorter wires and it looks like they were forced to switch the terminals from 234 to 243
So the take away is dont assume a picture on the interweb is correct and double check the wiring diagram and follow the leads back from the torch plug to the terminal. My 625 has a completely diff plug for the torch than the one in your pic. I assume Miller has used a couple of vendors for these things over the past few years
The 625 likely has a removable torch where the 375 is hardwired.
I bought my 375 extreme in 2007 or 2008 I’m sure revisions have been made.
I think their intent though is to have those terminals and right to left order two three four.
And then when they went to that new style torch they realized they didn’t have enough wire to make it to the four terminal so they switched them around.
Physical verification of what you actually have in reality is definitely a good step.
There’s also a couple of Hobart units that are almost identical to the Miller series.
Isn’t that the truth.
