4th part of the day and the THC stopped working. Had to restart Firecontrol for it to work again. First part had a non fire and I had to “run from here”.
Can you pull you THC cable from the electronics box and make sure you are getting 1-3 volts on those pins when the torch fires? That will help narrow down where the issue is.
