I recently got done upgrading my water tray, wanted to start cutting again and noticed that my THC isn’t connecting anymore.
I’m using a Mac on macOS Catalina 10.15.3, and FireControl 20.6
My system report shows that it does detect the THC
But the THC connection is always a dull green. I can click on it to get the dropdown menu but it doesn’t ever connect. Do I need to update the firmware to be able to use it now?
I believe there is a problem with the Mac os compatibility … with the newer versions of Fire Control.
you may have to backdate your OS to the last version.
I am searching to find the isue last posted
I was on an older version, I believe I had 20.5 installed initially. It was working before my water tray upgraded. I plugged it in, and THC wasn’t connected. I upgraded to 20.6 wondering if it would fix it but it didn’t.
I’m planning on bringing a windows in tomorrow to do the FW update.
Maybe I should hold off on that for now?
I’m on 10.15.3 Catalina and for the most part I don’t have any problems connecting. When I ran into this problem from my original post, I had to use a windows computer to flash the THC. I still don’t know why it happens, but flashing it seems to fix it.
