im cutting 0.250 plate with a slight warp in it. i made a few test cuts. the voltage test was all good for the thc but when i make a straight line cut about 23 inches long the z axis moves up gradually and about 5 inches into the cut its no longer making arc contact with the material. could this be happening if the 50:1 voltage input to the THC has the polarity switched? using a machine torch with an everlast 60s
you should be using RAW voltage hooked up inside the cutter on the everlast cutters. They have an inherent problem using the divided voltage from the CNC port. There are a few posts on here explaining that.
dude…seriously…you posted this problem in another thread…I guess you did not like my answer…so you posted the same question here…and guess what…you got the same answer…
asking the same question in different threads will only make people here not trust you…
