This is the sign I am trying to make.
I got the RENOVATIONS on the circle fine. Went to add ALL DAY at the top and it wont let me select the circle any longer. I can select some other piece of geometry ok, but not the large circle.
It’s almost like I need to do all the text at once? or make the circle into two separate pieces? All Day Renovations v6.f3d (117.1 KB)
@Wsidr1 OK I dont know what happened to the first file. I did get the text where I wanted it but as usual I am stuck again.
I made this from a picture first time for me and I can’t believe I made it as far as I did so far.
So somewhere in the process of making my sketch the canvines went away before I was done. So I had a sketch 1/2 done but I needed to add the state outline to it.
I went back to the original canvines and traced the state, then I copied that and pasted it to the sketch I had half done. and now I am stuck. Maybe now I have two sketchs one on top of the other?
If you would like to take a look please do and let me know what you think. ALL DAY v0.f3d (298.5 KB)
Hey Tin, I have never had any luck using History. Only options I have are current condition or original blank Sketch. What am I missing in Preferences? Or does the Non-Commercial user version just not have access to that feature?
I didn’t have time to watch the video, so maybe repeating here.
When you say “now I am stuck”, what else are you trying to do next?
Your letters still need work as many are overlapping each other or spilling outside the circle. I’d select them, Unfix, and hit “M” to bring up Move, then drag them where I wanted them. Several letters also need to be made into stencil font.
After that your gonna need to create some tabs/connections between what stays vs what gets cut out. Right now the center will just fall out when cut.
I have not watched the video yet but will tonight
I did strat with a Canvas first and traced over it. I think what maybe goofs up the time line is I get to a point and I save my work under a new file name. and may do this several times.
Yes the placement of the letters is what I tried working on. I did not know I could take and move individual letters I will look into that.
Everything in white will be cut and attached to a 36" round piece of wood.
Yeah, I’ve confirmed that and even though it says it’s capturing history, if I click on Previous Step, it always just goes to a blank sketch condition.
All of my “User Saved” saves show up in History when I open that option by right clicking on a tree component.
There’s no history in a sketch itself besides for undo and redo.
The history is if you had a sketch and then extruded and then started another sketch and then added a canvas. the history is for those different item features.
