Hi I just got the pro table and am using sheet cam and tap file won’t load in fire control I loaded post processors and only get “ glblindbuffer not available any thoughts, I have a cross fire that I use a lot with mach3 same computer with no problems ever.
Your OpenGL version is out of date. FireControl requires 3.0 or higher. You may be able to update your graphics drivers if the graphics on your system support 3 or higher. The second item in the following link:
There is a better message for this in the upcoming version than the stack trace.
