Just built my table and checked the Y calibration. It is -.007" off in 3" of travel. (my dial indicator is 3 inches) That’s .088" in 38", that’s too much. There is no backlash and the couplings are not slipping.
Yes my table is square. I did put the dial indicator on both Y axis and it is off .007" in 3" on both sides. Ive build other cnc machines and none of them have perfect lead screws on them. They always need tweaked a little. You do that by adjusting the steps per inch in software. Is there no way to do that?
What is the tolerance of the machine? I may have to get new lead screws.
Two openbuilds Cbeam router tables 1m x 1m. Four 3d printers, self sourced. Ratrig vore3 400mm is my latest build.
Here is a video of what I’m seeing. I’m I missing something. Open to any suggestions.
I checked all 3 lead screws and they are off the same.
I verified the dial indicator was correct using the DRO on the mill.
It calculates to .032" per 12", a little over spec.
I guess the worst its going to be is about a 1/8 in 4 foot.
Nice catch. Just put mine together and will be checking this too. Anything CNC really shouldn’t be that loose tolerance I wouldn’t think. My 1992 Nc mill is better than that and it is wore out.
If it is repeatable in several spots, it absolutely should be a software defined relationship that should be able to be tuned. Maybe not user adjusted, but definitely a tech line call should be able to tune this. Its just best practices to optimize everything you can on a machine.
I realize this is driving a torch, not a tool - but as I have a MR1 order in, similar tuning needs are often in similar products… The leadscrew hardware for the MR1 looks like same source or design in the videos trickling out.
This is not a solution, but I wonder if within Fire control if the scaling option could be used for that fine of adjustment over a 3 foot piece. Not sure if those fields support the number of decimals needed.
I am by far from a expert. I have fan quite a few very old pieces ofmachine shop equipment. Own several pieces. Ran several cnc. They all work better with a little TLC.
Could be something else wrong. It it was the calibration I wonder if it would have returned to zero?
The box with the screws was drop shipped from Igus. I looked on their web site and a found a tolerance of .1mm in 300mm so that’ s about .006" in 12" Not sure if that’s the same tolerance on the crossfire leadscrews.
I’m not sure where the stepper calculation are, in firmware or in the Firecontrol software. If its in the fire control sofware it would be easy to add some settings to calibrate the lead screws. If its in the firmware it would be more difficult for the user to change.
