I have an issue where surfacing starts out good on the first pass then crashes into the x axis end and then comes back and does not pass all the way to the left on the x due to the crash on the initial pass. I have attached a video link to show what is happening.
At first glance I’d say check your G54 coordinates. If I remember correctly the langmuir programs need your G54 X and Y set to the position the machine homes to, or maybe it’s machine zero come to think of it. It appears that the G54 X offset is set at 1.5518 inches and it is moving the whole tool path to the right due to the offset.
Setting G54 X and Y zero to the home position should take care of the travel problems.
Also, do you have the soft limits set and enabled on the machine? I can’t remember at what step they go over setting the travel limits, but with those set it will prevent the hard limits from crashing.
