had this issue for while now no matter the material or rpm or the cut feed rate, i first notice while doing the break-in program thought maybe it would go away since it was first getting used, but im going to check the belt tension today and see looking to see if anyone had similar issues and what fixed it for you
That is odd. No alarm or error messages when it happens?
If it happens for more than a second or two you might take the cover off the electronics cabinet and see what the spindle drive displays when this is happening.
I can’t think of hardly anything that would turn the spindle off and then back on off the top of my head but seeing what the other components are doing during the spindle stop or start woukd help diagnose where it’s coming from.
same thing i was thinking i have a video of the screen and from my understanding i didn’t get an error code it just went zero and back to number reading, i do have a question regarding the reading on the screen is it suppose to match the spindle RPM or no at 8k rpm im reading -.3960 thru -.3970
The spindle drive will read in the neighborhood of 4,000 rpm. The belt drive doubles the rpm at the ER spindle shaft.
With the drive showing the drop to zero and then jumping back to rpm I would check the connection of the 10v reference to the spindle drive. It’s a brown and white wire the best I can remember. If the voltage on that wire is steady and it has a good connection it may have to do with the 240v coming into the drive.
With no codes to base it off of I would say emailing support would be a good idea before getting too far in the weeds. I recently did some spindle motor diagnosis and verified my findings with Jake. I’m sure they can offer more things to check and monitor.
so today i was able to some more testing and im still not able to figure out whats happening, i swaped out the spindle controller with another unit with same problem & i swaped out the power supply and i ended up having more problems where it was triggering a “hard lmit switch error and to home machine” but it did the same error while in the home position and in the XY position above my material stock, so i put my original controlers back and now its back to normal but its still randomly stalling even on the spindle overide at 2k rpm or at 8k rpm
Just for the heck of it I would try toggling off the soft limits for a test run and see if it changes anything.
One of the last issues I had after changing my spindle motor was a cracked solder connection on a limit switch. When everything was sitting right it would run and it would lose that connection for a split second and shut the spindle off. Some of the time it gave me a limit switch alarm is what finally lead me to wiggling wires until I found the culprit.
Past that I’m hoping one of the Langmuir guys will chime in or I’d encourage you to email their support. The response isnt immediate but I always got some kind of response the same day or next morning.
