Hello, I like to keep my workshop as clean as possible. For example, I do not perform any grinding activity in this space, I go outside. Now, Plasma cutting does not generate as much dust as heavy grinding but it’s not a very clean process either. Anybody uses some genius solution to contain most of the flying sparks? I was thinking about some welding screens maybe all around the machine? However I would like to avoid something that is too bulky and cumbersome to deal with. Thanks
ahahahaha…the fine black smoke dust from Hell…
I have seen a lot of guys here build all kinds of enclosures…fire rated boxes with direct exhaust…ducted smoke eaters attached to the table…
surf around with the little magnifying glass…use different words…table mods…enclosures…venting…fire rated…
I found a bunch of things
Even with a water table this is a messy business. The fine black dust gets everywhere, it’s not about just sweeping it up. It drifts and get on top of everything. The best solution would be a hood over the table drawing the air outside.
no only on top…in electrical motors…if you have motors…place safe…put a little filter m,edia on the intakes…protect those magnets…
