Solving Crossfire Pro CUT60 EMI and Ground Loop issues once and for all
I have been chasing EMI and ground loop issues on my Crossfire Pro with Primeweld CUT60 for years. To be clear, I do not believe this is a Langmuir problem, the Primeweld CUT60 is known to be a noisy girl and was removed from their recommendations list. But that said, the Crossfire Pro electronics were not designed to have robust protection against such cutters that throw off a lot of noise.
What were my symptoms? The most common was simply disconnections to the electronics during a cut. But it gets worse, it has smoked laptop USB ports, cooked laptop speakers and touchscreen digitizer, released the magic smoke from resistors inside VIM modules, and caused problem after problem. THC signals were unreliable during live fire, and the voltage signal would stay floating high (very slowly lowering over time) even after the touch shut off. The problems were substantially worse when THC was used, regardless of whether I was using raw or divided. With THC wiring disconnected the issues were far less common, but not zero. Yes to all the usual troubleshooting, I removed PC power ground, yes there was absolutely no continuity between the controls chassis (i.e. USB ground) and the table, etc.
I have finally solved it once and for all using signal isolation modules for both the IHS and THC.
I now have zero issues.
I get an absolutely rock solid THC voltage signal, every time, every cut.
Isolation IS the key! The original design breaks several engineering design guidelines and literally begs for failure.
I have an OG Crossfire and added my own THC, IHS, Z Axis, and replaced the enclosure with a plastic NEMA 4 enclosure. The THC is the THC3T-02 which has an isolation power supply and, more importantly, an isolation amplifier as you have added to yours. I’ve never had a noise problem with mine.
Good job fixing yours!
You could sell this as a kit.
That is amazing: Solid information. Great description of the problems you were having.
Thanks for sharing.
Agree with BrownFox! (Second time for me publicly admitting that)
Congratulations on making it through the 5 stages of admitting I’m awesome.
I would love to, but to be honest I’m already drowning in my current workload!
Totally get it. Kick ass job putting it all together and providing a parts list.
Even just using some colored pencils to draw up up the wiring would be gold.
Here is the schematic, it is very straightforward to wire.
Here’s the Amazon one for reference, looks identical to the one used in your setup.
https://www.amazon.com/Isolated-Resistance-4-20mA-Converter-Conditioner/dp/B0FVFLY3R7?dib=eyJ2IjoiMSJ9.VcarpWjNKCCdEuySCfS938eluj1iEeTCoCpBU6CuacXAK6Qy4js2Hhu7rIzLytY34elWUfu6bRdBKpfkpzK-3CtaZLnmpTIzp_KV40scvK6pcaZ_rSSuV-LaCL7k4uRqe2uDZvp6XASLYYIuWe8lUm3lhD-O8TY4WzkIX6D_FHPTpp1UGQ4kjI4s7-CHHLDE6FyXn2PoX70FaovU1tmDePPQdZtBrKuKVDc8Wv8OO5s.MipXfG7lBWxWbpuIQjSffGE2PXN2--uAt2LjRR2kYIc&dib_tag=se&keywords=DIN%2Brail%2Bisolated%2Bsignal%2Bconditioner%2B0-5V&qid=1764096153&sr=8-9&xpid=NajUhfL-_cwAe&th=1
This is brilliant! Thank you, I plan to build one for my setup. (I have a Cut 60 as well…)
The link to the 0.5v to 0.5v isolation for THC appears to have expired. I can find a similar unit on Amazon but can’t quite find one with a stated 0-5v output. I can find a 0-10v output easily however. Do you imagine that would work? Could you provide any other info on yours so I can hunt one down? Thanks again!
Will this work?
https://www.amazon.com/Isolator-Transmitter-Intelligent-INPUT_0-5V-OUTPUT_DC24V/dp/B0DZ64Q5FF?th=1
This looks good! Thanks, I’ll give it a try.
Just found the original on Ali Express! $15
Post the link.
Whoops……Good idea :slight_smile:
Price went up ($23 now) but still much cheaper than what was on Amazon.
https://www.aliexpress.us/item/3256809726479192.html?src=google&pdp_npi=4%40dis!USD!16.71!16.71!!!!!%40!12000050558329502!ppc!!!&gatewayAdapt=glo2usa
Building one of these from your parts list and schematic. Thank you very much!
To confirm, is the 36 V power supply heading to the 24 V buck transformer coming from inside the Langmuir box?
Yes, it is the Stepper Motor power supply.
Thanks for the clarification. Should have this up and running soon!
As it happens, my Ground loop isolator that has been heavily suggested by members here.,…died yesterday. Going to give this a shot.
Waiting for @tseeger to post his results.
