Solved: Need help with tool set procedure
After an auto tool set, my tool tip is way below the workpiece Z zero. I haven’t found the instruction set for probing or tool setting, but it appears to be pretty straight forward. Here is how I am doing it:
Calibrate Probe Routine (against tool setter).
Probe Workpiece X,Y and Z corner mode.
Install tool and perform Auto Tool Set.
X and Y always are spot on but Z is always off. What am I doing wrong?
Thanks!
I found the video on it. I was doing it out of order.
It should have been:
Probe workpiece
Calibrate probe
Auto Tool Set
